Noticed Outside Temp Sensor had fallen out of its clip and was way down in the bottom of front bumper...re-installed in proper location, now the temp no longer reads 40 degrees too high!!! Now it agrees with Weather Channel app.
Lubed "clutch pedal spring" under dash--no more squeak!!
Took apart accelerator pedal assembly. Lubed the two ball joints inside it-- no more "sticky" accelerator!!!
