Windows (both) stuck in down position
Hoping for a little troubleshooting help on this one. MY 99 USA. Both windows (driver passenger) went all the down today via the switch , also put the top down today. Went to put the top up later and no luck. Some searching led me to the brake light not coming on when brake is engaged, so I worked the hand brake a few times , got the brake light to come on and the top works just fine now. However , after getting the top up I went to roll both windows up and nada, no click , no movement , zero. Checked the 15 and 30 amp fuse and both are good. Im stumped as to why both windows have failed and if it has something to do with the intermittent brake light switch causing the top to have issues today. I can see no info on a window relay.
Any troubleshooting suggestions on where to start ?
Thanks !
