Old 05-02-2015, 05:46 AM   #2
JFP in PA
Originally Posted by eicheldp View Post
I just purchased a Durametric cable and attached it to my MY04S with a Tiptronic. I ran a scan of the car and two fault codes were displayed.
P1818 Pressure Regulator 2
P1823 Pressure Regulator 3
Is this something serious? To my knowledge the transmission has never been worked on.
Any help will be appreciated
The Tip valve body and pump system uses several solenoid valves to control pressure and flow within the system. These valves tend to get gummed up with debris and varnish if the fluid is not changed regularly, and on a much shorter cycle than the factory suggests. If the blockages become bad enough, the unit has to come apart for replacements, which ain't cheap.
