Originally Posted by Dlirium
Holy Cow, KRAM! Thanks for sharing, this is an amazing write up! Now I just have to get up the nerve to try!!
You're welcome. This is a time consuming Mod. The hardest part I found was getting the last bolt out of the intake plenum. I took the Plenum completely out of the way, makes installing the 987 air box easy. I didn't have a hard time at all putting the 987 air box in place. Second hardest thing, making sure you cut the silicone hose to the proper length. Tip on cutting the silicone hose itself, take one of the clamps and tighten it down on the hose were you want to cut it, then just use a box knife cutting right at the clamp, makes a nice straight cut.
