Old 05-01-2015, 08:54 AM   #1
ppbon
ppbon's Avatar
You cannot use the AirLift to pressure test.
It's the opposite. The Airlift creates a vacuum.
You can test for leaks after you empty the coolant by drawing a vacuum and waiting 5 minutes. If the vacuum holds then there are no leaks.
But if you're hunting for a leak, you need to put pressure in the system with coolant to physically see where the leak is happening.
Happy Boxstering,
Pedro
Originally Posted by Chuck W. View Post
Can I use the Airlift 550000 for the pressure test? I have never used one and haven't even opened the box.
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
