Old 04-30-2015, 05:46 PM   #3
BFeller
I decided against trying to disconnect the air conditioning compressor. I did bleed the system using the process detailed in the Bentley Manual and at Pedro's website. A big air bubble pushed through. A test drive provided much more heat for a while. I switched to Auto Climate control and afterwards it seemed like there was less heat. When I got back there was evidence of steam on the trunk lid above the coolant fill. A new cap and o rings for the bleeder valve are on order. I am also in possession of a pressure tester of the coolant system. So I will replace the o rings then pressure test the system.
BFeller is online now   Reply With Quote
