Originally Posted by BobRickel
I had the same problem. I replaced the door latch mechanism on my 97 Boxster. It did not cure the problem. When I pull on either the inside or outside handle and open the door the interior lights go on but when I let go of either handle the window pops back up. I know the micro switches are working on both handles and the latch switch is working because the interior lights come on. Any Ideas would be appreciated.
Check all the door wires, i have 97, i found corroded and cracked wirerubber, I some how partial solved the problem. I had the same symptom.
