Old 04-29-2015, 02:29 PM   #11
Luv2Box
Luv2Box's Avatar
Originally Posted by KRAM36 View Post
The Tiptronic heats up more when using manual mode. There is definitely an affect on the trans using it that way.
It does not heat the trans up enough to cause damage, if you check the manual you will see that Porsche says it is ok to downshift the trans to slow down.
Luv2Box is offline   Reply With Quote
