Old 04-29-2015, 02:20 PM   #11
healthservices
Registered Boxster abuser
healthservices's Avatar
Well even thought mine did not have the trunk release actuator in the trunk, it was wired for one!
And the actuator is available used for as little as $35 online today
But of course if you want to install a less expensive actuator you can too.
You will most likely need to use a relay for at least the aftermarket actuator as it draws a few amps
