Old 04-28-2015, 06:08 PM   #21
particlewave
The wires run up to near the door handle release cable, where they enter the door. The airbag stays in the door when the panel is removed (minus the cover on the door panel), so no big worry there. I would unhook the battery anytime you are messing around with wiring.
The wires eventually run to the doors main connector. I would imagine that there is power there somewhere. I'll check the wiring diagram tonight.
