Old 04-26-2015, 07:39 PM   #17
tommy583
98 Arctic silver 986
tommy583's Avatar
Just use some coat hangar wire for a rod. Make sure you hook the batteries up in series to get 24 volts!
I take no responsibility if you actually try this, btw. None. Zip. Nada. I'll put this on the same page as using ether to set your tires on the bead.
Be pretty cool if it worked though... Probably S.O.P. for the boiler banger.
I actually think I will use 3 batteries to make sure I have enough power. And yes I would definitely be using a coat hanger. No sense in wasting money on welding rod. I will need that money for the hospital bills lol.
tommy583 is online now   Reply With Quote
