Just use some coat hangar wire for a rod. Make sure you hook the batteries up in series to get 24 volts!
I take no responsibility if you actually try this, btw. None. Zip. Nada. I'll put this on the same page as using ether to set your tires on the bead.
Be pretty cool if it worked though... Probably S.O.P. for the boiler banger.
