Old 04-26-2015, 06:24 PM   #946
particlewave
Originally Posted by jaykay View Post
Wil non lit (retrofited) lights plug into to a factory lit car without problems; plug and play? Can one set it up so that you can switch back to stock (factory lit) at will
Yes, they would be plug-and-play. Litronics have the normal headlight connector and a separate connector for the Lit level controller. You would just install the standard retrofitted headlights and leave the second Lit controller connector tied back. If you wanted to revert to Litronics, just reinstall them and plug the level controller connector back into the Litronic headlights.
Edit: Bruce beat me to it.
