Old 04-26-2015, 06:05 PM   #11
tommy583
98 Arctic silver 986
tommy583's Avatar
OK guys here is the status. Bolt still stuck. Filled up the hole on the back side of the bolt with PB blaster. Put old rotor back on. Put wheel back on. Letting it sit for at least another night. I did put some heat on it, but not enough to get it red hot. I was really hoping to save the threads in the hub. I'm thinking if i get everything red hot then the threads are shot.
I will call my indy in the am to see if he has any tips. I will probably let it sit with the PB blaster for a couple days as the weather will be crappy anyways. Right now the caliper is hanging behind the hub with some zip ties. The nuts are still on the bolt. After the weather clears up in a couple days I may give it one more try. Depending on what the indy says I may go with red hot heat. Or i may just tow it in later in the week. Any new tips or prayers are appreciated lol.
tommy583 is online now   Reply With Quote
