Old 04-25-2015, 05:41 AM   #12
KRAM36
Need For Speed
KRAM36's Avatar
Originally Posted by akwarner View Post
Thanks. I checked my records and a new AOS was installed last October. I've driven less than 1500 miles since then. I am not comfortable pulling parts off the engine to look at that so I may have the shop take a look the next time I have it back for service. I am up for an emission check in August.
A.
If your car never dumps out smoke you're more then likely good. The previous failed AOS probably mucked up that cat. I also forgot about the removing the oil cap to check on the vacuum pressure, you could do that yourself.
2003 Boxster S
