Old 04-24-2015, 09:21 PM   #27
KRAM36
Need For Speed
KRAM36's Avatar
Let's clear up the confusion (I think even Martin was confused).
What you are seeing in this picture on the front of the bearing is not a seal, but part of the cage.
Again, this is the front of the bearing and this is part of the cage, not a seal.
This picture shows the rear of the bearing. This is a seal.
And finally, here is a picture of the rear of the bearing (again) with the seal removed. Note the cage including the rear portion which is a shield and part of the cage structure, not a seal.
This is absolutely, positively an LNE ceramic bearing with inner seal only.
Where's that door? It's dark in here.
I need a potato break...
2003 Boxster S
