Old 04-24-2015, 08:09 PM   #26
particlewave
Let's clear up the confusion (I think even Martin was confused).
What you are seeing in this picture on the front of the bearing is not a seal, but part of the cage.
Again, this is the front of the bearing and this is part of the cage, not a seal.
This picture shows the rear of the bearing. This is a seal.
And finally, here is a picture of the rear of the bearing (again) with the seal removed. Note the cage including the rear portion which is a shield and part of the cage structure, not a seal.
This is absolutely, positively an LNE ceramic bearing with inner seal only.
Where's that door? It's dark in here.
I need a potato break...
