You need a simple code reader.
You then do not have to disconnect battery to reset.
At this point you don't know what the code was so you can't target your repair.
Hunting idle can be due to dirty Throttle body/Intake (My issue - didn't throw code nor was power down)
I have also read that disconnecting the MAF is a diagnostic test. You should be able to hear it in the idle if it is hunting
Seal Grey
