Originally Posted by kyle986driver
hi, i was just wondering if you guys are running tires of equal width in the front and back of your 2000 boxsters? i saw a guy with the same car as me with equal tire widths and said his car handles awsome. Mine (bought used) has rather small tires in the front and MASSIVE ones in the back, and i thought this would maybe contribut to my cars MASSIVE understeer.... thanks
Hi,
Putting wider rubber on the Fronts will tend to neutralize the steering some, but at the expense of Turn-in and possible Tramlining and vibration at higher speeds.
Understeer is inherent in most Production Cars, but it's not really excessive on the Boxster.
If your's is, I would look to an Alignment before deciding to fatten the Rubber. Also, try going up a few PSI in the Rears, this too will mitigate some of the effect. Hope this helps...
Happy Motoring!... Jim'99
