Old 04-20-2015, 08:14 AM   #1
Bruce Wayne
Bruce Wayne's Avatar
Originally Posted by Raphael Gergi View Post
Thank you guys for your replies
I took it to a Transmission specialist with over 35 years of experience, turned out to have a speedometer malfunctioning as well as having to strip the transmission and rebuild it, that would cost around 1200$.
An Air Mass sensor needs to be changed as well for what it showed on the Scanner.
As soon as im done from that I will have to sell the car and go for an E92 335i coupe or an E46 M3... what are your thoughts?
Transmission rebuild What is the diagnosis ? like i said it sounds like it needs a fluid and filter change.. try that first and see what the results are
What did the scanner show for diagnosis on the Air Mass Sensor ? I've just ordered a replacement one due to the the live data showing an issue. see here : Lambda high - No fault codes
986 x2 6sp
2x Range Rover Vogue 4.6
2004 MX5 Sport 6speed Strato Blue (wifelet)
2x Range Rover Classic & CSK
Bruce Wayne is offline   Reply With Quote
