was the filter changed when the fluid was changed ????
It sounds from the off that it isnt working properly until the fluid has heated up and the viscosity changed. If the filter is clogged up from repeated changes without being changed that would cause similar effects.
986 x2 6sp
2x Range Rover Vogue 4.6
2004 MX5 Sport 6speed Strato Blue (wifelet)
2x Range Rover Classic & CSK
