Old 04-18-2015, 07:42 PM   #14
KRAM36
Need For Speed
KRAM36's Avatar
It's just not possible, bro. The wire is even clipped into the pad retaining bracket so it cannot possibly touch the rotor. Only a micrometer can check the rotor thickness.
Please. I'm begging you. Think about it.
If not, make it $100??
Well then these guys are giving out bad information.
Grinding, pulsating and a lack of stopping power are signs of a bad brake rotor. If your brake pads have worn deep into your rotor, the lip on the outer edge of the rotor can cut into your pad wear sensors, causing a brake pad warning to appear in the instrument cluster - even if your brake pads are new. Rotors should be checked every time you service your brakes.
2003 Porsche Boxster Roadster S H6 3.2L Braking Rotors - 99635140501KT - Front Brake Rotors - Pair 12.51" (318mm) - ES#2535370
2003 Boxster S
