Old 04-17-2015, 08:32 AM   #12
flaps10
flaps10's Avatar
Assuming the cam timing is where it is supposed to be, take a look at your crank position sensor, they can cause an intermittent non coding no start condition where the engine just spins over.
I was going to suggest the same thing. I would think an OBD2 reader might uncover that, but if you have the engine laying on the ground that is out.
I wonder if there is a way to bench test the sensor. Perhaps a resistance check with a multimeter while you whiz a piece of metal past the end. It's just a Hall sensor isn't it?
If the engine were in the car you could just swap it with a known good one, but again you'll have to reassemble the whole beast before that is an option.
Either way I'm tuned in for the fix. Best wishes to the OP.
edit: just re read JFP's post about it not pulling a code. That puts us back at bench testing or replacing with a known good sensor.
flaps10 is offline   Reply With Quote
