Old 04-15-2015, 05:31 PM   #1
NewArt
Artist, 986S tinkerer
NewArt's Avatar
As Byprodriver suggested, I don't think you have conducted your leakdown test according to Hoyle. Make sure you are at TDC on the compression stroke for each cylinder. Otherwise you may have a valve partially open resulting in false readings. Also, it is not accurate to do this test on a cold engine.
Ah, okay, I see that you have answered back while I was typing. Still the cold engine thing though. The rings won't make a good seal.
