Thread: V8 Conversion
Old 04-15-2015, 12:47 PM   #11
martsink
Hey guys,
I just spoke to Renegade yesterday, the kit should be on its way next week! I also started fabricating the reinforcement plate to replace all that metal that I cut out, but I have no pictures to show you. I probably won't be welding it in until I get weld-thru primer and good aerosol 2K primer. I might also get some seam sealer to seal the welds and keep the moisture out. There was a whole bunch of water inside the body when I was cutting it up, so just want to make sure the reinforcement plate doesn't rust.
Since it's been a little slow lately, I decided to run up the total for my build up to this point. You can find the updated BOM here. This does not include everything, I still need: seats, brake lines, starter, alternator, belt, power steering fittings, headlights, water pump, water hoses, and whatever else I'm forgetting.
martsink is offline   Reply With Quote
