The max deviation is +/-6deg from the factory but I've seen them run +/-9 and not break - but according to specs your one side is out in excess of 2 degrees...
The cam sliders are fairly thin to start with and you wont see a whole lot of debris until its almost too late. I had one running at +6.2 and when I changed them out the upper of the two sliders was almost through on the chain edges.
If it breaks and the chain breaks the plastic into bigger bits and or gets caught on any metal of the cam assembly you can kiss it goodnight.
Just my thought...
H
Previously owned:
