Old 04-13-2015, 08:49 AM   #1
jml911
Originally Posted by Qmulus View Post
The diagnostics built into the ECU/DME is the place to start. If you have a driveability issue that severe it will have faults in the ECU. It is also helpful to know what year/engine/injection system you have.
Well it's a 2000 but we've changed a lot
it's not a 3.2 anymore put it that way - bigger injectors - the lot
We can't read any faults at the track. Our machine for some reason isn't picking up the fault. It's a "soft fault" for sure as it's reset by turning the ignition on and off.
jml911 is offline   Reply With Quote
