Thread: Audi Swap
Old 04-12-2015, 11:57 PM   #15
The Radium King
The Radium King's Avatar
cool. i ask because the torsen (similar to quaif) automatic torque biasing rear differential from a v8 audi will go into an audi 012 5-speed with just a bit of machining. apparently easily found at wreckers. the issue is that the diff will only accept audi axle flanges. apparently this is an issue for the 944 guys (they have an audi 016 in the back of their cars) put perhaps because they use 8mm axle bolts as well. otherwise a $200 solution to the $2000 limited slip issue.
