I did the electrical installation portion of the IMS Guardian. Everything in the dash was done and hooked up to the fuse box. Did an operation test by grounding the detector/oil plug and testing the switch as well as the magnetic contacts. All good. I am now at the point where I have to run the detector/oil plug wire into the engine area. That will be next weekend along with oil sump inspection and oil change. Fun project.
