Thread: Audi Swap
Old 04-12-2015, 07:14 PM   #14
KenDFW
question - do you have confirmation that the audi flanges will work with a 6-speed axle (proper diameter, M10 fasteners, etc.)? thanks, trk.
Hi Radium King! I have the old audi axles in my garage along with the oem bolts.
Boxster 2.5/2.7 uses 8mm bolts (That's why I had to swap axles)
So the Boxster S uses 10x50mm bolts
The 1.8 A4 FWD axle bolts are 10x48mm 12mm triple square head bolts
So- the bolts will work and screw in.
I can take measurements of the axles. If the audi axle pattern will work with the Boxster S cv joint pattern, then this will get interesting. There are 6 holes, and the bolts will thread.
It wouldn't surprise me as Porsche and Audi share some parts!
KenDFW is offline   Reply With Quote
