Old 04-11-2015, 12:01 PM   #4
The Radium King
The Radium King's Avatar
arrg. i knew the speed sensors changed in 2002, but thought that it was due to the change in abs from 5.3 to 5.7 - didn't realise the axles changed because of this as well.
so, that kills the 987 axle idea. i've been doing a bit of research (bearing cross-referencing) and the 986 5-speed axles might still work. the difference in 5- and 6-speed rear wheel bearings is in OD (+5mm for the S) and depth (+5mm for the S); the ID diameters are the same. So, i might be able to keep wheel carriers, wheel bearings, etc., and just use the 5-speed hubs with the 5-speed axles. from what i can see, only downfall is 5mm less thread for the axle nut.
possible?
