Thread: Audi Swap
Old 04-10-2015, 04:15 PM   #1
KenDFW
Originally Posted by healthservices View Post
Cool beans!
I'll have to try this the next time!
Have any more pictures of the two transmissions?
Any other things have to be swapped between the two transmisions ?
Valve bodies, connectors etc.
No codes plug and play?
Once you see the transmissions side by side, it is very self explanatory as to what needs to be swapped. The one thing you have to is the axle shafts. The gear shifting hardware is external and is held on by bolts. It takes 5 minutes to unbolt and move over.
No codes. If you have a tiptronic though, no dice.
KenDFW is offline   Reply With Quote
