When you do the oil change give the filter and the oil itself a real good look. Anything out of the ordinary like plastic bits or metal shavings should be investigated. How long was it stored and was an oil change done before storage or did it sit with used oil. Also, you might want to put in a magnetic drain plug when you change the oil.
Not to open a new discussion but you know where I am heading with this . . . . . An ounce of prevention is worth a pound of cure.
BTW, You are going to love the car.
