Spent two hours Tuesday removing the front motor mount after draining the cooling. I also mounted the new one in the yoke. Wednesday spend two and a half hours torquing the mount into the yoke and reinstalling the entire assembly. It is bit more fiddly going back on the car. I also removed the water pump and thermostat and installing the replacements. Tomorrow will be set aside to reattach the coolant hoses and try the Uview to test the seal. There is a new belt ready to go and fresh coolant in jugs ready for the refill. Hopefully it will be on the road by the weekend.
