Old 04-08-2015, 07:12 PM   #1
jaykay
jaykay's Avatar
When you replaced the tensioners did you install the updated IMS tensioner with the large preload spring? It is critical to optimize the issue. If you remove it you can inspect the IMS tensioner paddle wear button for wear. If it is worn down flat, you have excessive clearance requiring removal of the crankshaft housing to replace the paddle.
Do you have a picture of this tensioner? The one I installled (latest rec.) did not have a large external pre-load spring
986 00S
