They will do both an ecu check, and a tail pipe sniffer check. Make sure you get the cat converter nice and hot. It works better hot. If disconnecting the battery has truly erased the ecu, then you'll want to drive it around for a week or two to uild up some historical info in the ecu (ask me how I know). If you fail, most places will let you do a retest for $10 after a few days. Good luck.
Tony
Lapis Blue 03 Boxster S
