Thanks Kevin for the info. Then it sounds like Softronic simply takes a Duramteric cable and then adds a software key to allow someone to flash tune their vehicle.
So the cable I have is a Duramteric Enthusiasts cable that also has a license built into it to flash tune a vehicle through Softronic.
If you already have a Durametric cable then you can buy a software code from Softronic that will allow you to use your cable for a flash tune.
Originally Posted by winter.k
Thanks for the info Greg.
I also heard back from Softronic also. The software works with any durametric cable. They also sell the software with a discount if you have your own durametric cable already. The cable that comes with the softronic tune is a durametric cable that the put their sticker on (as shown above).
