Old 04-08-2015, 11:45 AM   #1
eliot92
986 Tiptronic Error (Flashing between D/4)
I have a 2000 2.7 Boxster 986. I can't seem to keep up with fixing it recently as everything keep breaking on it and its such a shame as I really love the car. It was literally in the garage less than a week ago having a new oxygen sensor fitted as it was misfiring. I've also had a huge amount of work carried out on it recently at the dealer (RMS, Coilpacks, spark plugs, full service, engine and gearbox cleaned, gearbox seals changed, exhaust mounts, brakes, aircon pipes etc etc) so I just want the car working again! I only mention this work as I wonder if the gearbox work could be related to my issue and before I have to book my car in yet again, I was wondering if anyone had any suggestions.
Basically every so often the car gear selector chart on the instrument cluster flashes between P/R/N/D (depending on which is engaged) and 4th gear, even if you aren't in 4th gear. Researching this suggests that this is a warning for a fault with the tip gearbox.
The weird thing is though that the car seems to be shifting gears quite happily, doesn't feel like there is an issue. It doesn't seem to let me go into manual mode when this fault occurs but I think that's a precaution of the error light?
I tried resetting everything by disconnecting the battery, this seemed to solve it for a couple days, then it happened again tonight albeit only for about a minute, then it went back to normal.
Anyone got any ideas what could be causing this? Thanks for any suggestions.
eliot92 is offline   Reply With Quote
