Old 04-08-2015, 10:47 AM   #1
Gremlin
The door speakers are bass only and the amp passes only LF bass to them. If you want full range in the door speakers, the easiest method is to bypass the amp and make the door speakers the "rear speakers" when wiring to your receiver.
I did the same thing in the last couple of days. Replaced the head unit with Kenwood and dash speakers with Kicker. MUCH better sound. Next I will replace the door speakers and wire them directly to the Kenwood. Since I drive with the top down most of the time, I am not looking for audiophile results.
If you do a search, there are several threads on this issue.
Gremlin is offline   Reply With Quote
