Thread: V8 Conversion
Old 04-06-2015, 08:39 PM   #11
martsink
There’s still no word on the status of the mounting kit, so I guess for now I just have to suck it up and wait. Today I started cutting the engine compartment to make clearance for the engine. It was a lot harder than I thought, the sheet metal is reinforced and having the car on jack stands does not provide enough room. I found it was easier to first drill out all the tack welds on the reinforcements to detach them from the actual sheet metal. This makes cutting and bending away the metal much easier. There was quite a bit of water in the enclosed compartment, which got me a little worried, but thankfully there was no rust.
Today I only had enough time to do a rough cut on the left side, but hopefully tomorrow I can finish it up if I can find my rotary tools. I also plan on making a reinforcement brace to replace all the missing sheet metal and also make relocation bracket for the e-brake.
The puddle on the floor is all the water that came out
martsink is offline   Reply With Quote
