Old 04-06-2015, 08:27 AM   #1
DrCactus
DrCactus's Avatar
I just had mine out the other day - pretty simple install actually. You need to put your car in service mode and go through to your engine. The step just before seeing your engine bay is when you re-install / or remove the back speaker shelf - there is only two pre-installed turn screw clips that clip into pre-drilled holes.... very simple. 2-3min job from start to end. Take a look on youtube for video on installing new air filter and the video will give you a good idea what I am describing.
DrCactus
