Old 04-04-2015, 09:32 AM   #2
JFP in PA
Originally Posted by redeye280z View Post
I changed the expansion tank because and refilled the system with airlift system so I would be able to get all air out. I did have a problem with the seals on the relief valve so I changed them. Now after a couple of test drive the I can see the antifreeze expands and leaks from the overflow tube. The problem is now the level is low so I filled back to minimum line and went for another drive and had the same thing happen. What gives?
What are the last two part number digits on your tank cap?
