Old 04-04-2015, 04:58 AM   #1
redeye280z
2 fast 4 U
Coolant overflow
I changed the expansion tank because and refilled the system with airlift system so I would be able to get all air out. I did have a problem with the seals on the relief valve so I changed them. Now after a couple of test drive the I can see the antifreeze expands and leaks from the overflow tube. The problem is now the level is low so I filled back to minimum line and went for another drive and had the same thing happen. What gives?
Drive it the way it's meant to be driven!
2000 Boxster S
redeye280z is offline   Reply With Quote
