Old 04-03-2015, 07:12 PM   #1
hancock1701
Originally Posted by Chuck W. View Post
I am gathering all of the parts and fluids to change the water pump on my '01 Boxster S, 25,000 miles.
I am going to do the pump, thermostat (low temp), belt, coolant and the hoses at the water pump. I have found the part numbers for everything but the water hoses.
Are there certain water hose(s) that should be changed while I am in there? I was also considering changing out the motor mount to the 987 one while doing this. Thoughts? TIA
I recently did these, too, plus the motor mount and had a thread about this with tips from other people as well that might be useful to you.
My car was at 135k miles, and the motor mount was absolutely worth it, or necessary. The old one was extremely disintegrated.
My first mistake was not raising the front end to drain coolant from the radiators, so I had to redo that part. Also, I followed the manual coolant bleeding procedure (Bentley, Pedro's Garage) the first time, but didn't get certain results. I actually bought the Airlift kit and redid the bleeding. It was so much easier and faster with that tool.
Anyway, good luck with the repair!
hancock1701 is offline   Reply With Quote
