Old 04-01-2015, 03:06 AM   #2
KRAM36
Need For Speed
KRAM36's Avatar
There are too many things this tool does for a person to sit here and tell you.
First of all I assume you purchased it because you got a CEL? That's the first thing you go after is looking at the fault code section in each module.
Once you have fixed those there are several other things to do. Like the quick system test, checking your cam deviation, ready status and much more.
If your car has OBC it can be used to turn that feature on for the 4 stalk.
Originally Posted by KRAM36 View Post
4 Stalk is in and functioning perfectly. Thanks for the killer wire harness Pdwight!
2003 Boxster S
