Old 03-31-2015, 03:09 PM   #2
JFP in PA
Originally Posted by Xcellr8 View Post
In the middle of a clutch job for a 98 and when I pulled the flywheel found an IMS bearing cover that did not appear factory as it had no markings at all. Whose IMS bearing cover is that? The previous owner had no paperwork so we are only guessing that the bearing has been addressed at sometime in the past.
Is it true that all factory IMS bearing covers had markings (Germany - for example)?
Thanks, Joe
Without seeing the actual cover, it is hard to tell. Porsche actual produced a replacement cover that had better seals to cure oil leaks that looked somewhat different than the factory flange cover.
