Tire shops usually have a set of special sockets. You hammer the appropriate socket on the locking lugnut, it cuts itself into the head and you can then just use a breaker bar to remove the nut. All the serious wheel thieves have such a set, so locking lugnuts are useless and just cause you grief when you loose the key. Just replace with normal lugnuts.
