Old 03-29-2015, 03:07 PM   #3
mikefocke
The important part, if I understand correctly, is the inspection of the filter and the dropped pan for any ferrous material. You want to make sure there is no debris that could take out the new bearing. If you find debris, then a rebuild with an emphasis on cleaning out the oil passages or a replacement of the motor with a clean one are about your only choices. Or you could drive it till it gernades.
