Right, today i checked the left side to see if i get the same readings in the connector as i do on the right and i do. As the left works and the right doesn't, knowing that both speakers work ok, i'm thinking this is a fault with the amp. I am struggling to locate a replacement amp, plus i am only assuming it is the amp at fault. I might see if i can get it tested and/or repaired if needed.
Does anyone know if you can buy an aftermarket amp that will work with the MOST fiber optic system (plug and play)? I don't want to change the PCM unit as i want to keep the stock appearance.
Steve
_________________________
2004 Boxster 2.7 - Atlas Grey
