Originally Posted by bwillia080261
I have an 01 S model with the 18" staggered wheel option. My question is what do you guys do for air pressure? I know the plaque says 29 front and 36 rear but with the extra load tires that are so common in these sizes that still feels like a lot. There is ZERO sidewall bulge at that pressure and the front end feels nervous. Has anybody experimented with lower pressures? Thanks
If anything, I put in a couple pounds more. I think with less you are going to see uneven wear from the sides and middle. My wheel man says a little extra helps keep from bending a rim on the many potholes we seem to have also. Not much rubber there for cushion.
